A nonlinear Luenberger-like observer for nonlinear singular systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2017
This paper investigates observer design problem for a large class of nonlinear singular systems with multiple outputs. We firstly regularize the singular system by injecting the derivative of outputs into the system. Then differential geometric method is applied to transform the regularized system into a simple normal form, for which a Luenberger-like observer is proposed.
Automatique
Automatica.pdf (164.41 Ko) Télécharger le fichier
hal-01649492 , version 1 (27-11-2017)
Gang Zheng, Driss Boutat, Haoping Wang. A nonlinear Luenberger-like observer for nonlinear singular systems. Automatica, 2017, 86, pp.11-17. ⟨10.1016/j.automatica.2017.08.018⟩. ⟨hal-01649492⟩
541 Consultations
493 Téléchargements
