New interface
Conference papers
DFA on LS-Designs with a Practical Implementation on SCREAM
Abstract : LS-Designs are a family of SPN-based block ciphers whose linear layer is based on the so-called interleaved construction. They will be dedicated to low-end devices with high performance and low-resource constraints, objects which need to be resistant to physical attacks. In this paper we describe a complete Differential Fault Analysis against LS-Designs and also on other families of SPN-based block ciphers. First we explain how fault attacks can be used against their implementations depending on fault models. Then, we validate the DFA in a practical example on a hardware implementation of SCREAM running on an FPGA. The faults have been injected using electromagnetic pulses during the execution of SCREAM and the faulty ciphertexts have been used to recover the key's bits. Finally, we discuss some countermeasures that could be used to thwart such attacks.
Document type :
Conference papers
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01649974
Contributor : Anne Canteaut Connect in order to contact the contributor
Submitted on : Tuesday, November 28, 2017 - 10:15:49 AM
Last modification on : Tuesday, October 25, 2022 - 4:18:14 PM
File
paper_4.pdf
Identifiers
Citation
Benjamin Lac, Anne Canteaut, Jacques Jean-Alain Fournier, Renaud Sirdey. DFA on LS-Designs with a Practical Implementation on SCREAM. COSADE 2017 - Constructive Side-Channel Analysis and Secure Design, Apr 2017, Paris, France. pp.223--247, ⟨10.1007/978-3-319-64647-3_14⟩. ⟨hal-01649974⟩
Share
Metrics
Record views
267
Files downloads
180
