AMONG Implied Constraints for Two Families of Time-Series Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider, for an integer time series, two families of constraints restricting the max, and the sum, respectively, of the surfaces of the elements of the sub-series corresponding to occurrences of some pattern. In recent work these families were identified as the most difficult to solve compared to all other time-series constraints. For all patterns of the time-series constraints catalogue, we provide a unique per family parameterised among implied constraint that can be imposed on any prefix/suffix of a time-series. Experiments show that it reduces both the number of backtracks/time spent by up to 4/3 orders of magnitude.
paper.pdf (750.99 Ko) Télécharger le fichier
hal-01651585 , version 1 (29-11-2017)
Ekaterina Arafailova, Nicolas Beldiceanu, Helmut Simonis. AMONG Implied Constraints for Two Families of Time-Series Constraints. CP 2017 : 23rd International Conference on Principles and Practice of Constraint Programming, Aug 2017, Melbourne, Australia. ⟨10.1007/978-3-319-66158-2_3⟩. ⟨hal-01651585⟩
116 Consultations
121 Téléchargements
