Sequential Purchase Recommendation System for E-Commerce Sites - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (1) , (1)
1
Shivani Saini
  • Function : Author
  • PersonId : 1024442
Sunil Saumya
  • Function : Author
  • PersonId : 1024443
Jyoti Prakash Singh
  • Function : Author
  • PersonId : 1024444
To find out which product should be recommended to the customer and when to recommend is done by the recommender system. Different approaches by using customer profile and product description are used to build recommender system. Although these information are not enough to recommend, sometimes buying of some products occurs in a stepwise manner, where buying of one product follows the buying of other products. The purpose of this research is to find the sequences followed by customers while purchasing products to improve the efficiency of recommender system. Sequence pattern mining is used to find out the order of purchasing products. The duration we find tells the time gap between the purchased product and recommendation of next sequential products.
448933_1_En_31_Chapter.pdf (285.18 Ko) Télécharger le fichier
Dates and versions
hal-01656206 , version 1 (05-12-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Shivani Saini, Sunil Saumya, Jyoti Prakash Singh. Sequential Purchase Recommendation System for E-Commerce Sites. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.366-375, ⟨10.1007/978-3-319-59105-6_31⟩. ⟨hal-01656206⟩
183 View
204 Download
Share
