Keystroke Dynamics and Finger Knuckle Imaging Fusion for Continuous User Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tomasz Emanuel Wesołowski
  • Fonction : Auteur
  • PersonId : 1024493
Rafal Doroz
  • Fonction : Auteur
  • PersonId : 1011362
Krzysztof Wrobel
  • Fonction : Auteur
  • PersonId : 1011363
Hossein Safaverdi
  • Fonction : Auteur
  • PersonId : 1024494
The paper presents a novel user identity verification method based on fusion of keystroke dynamics and knuckle images analysis. In our solution the verification is performed by an ensemble of classifiers used to verify the identity of an active user. A proposed verification module works on a database which comprises of data representing keystroke dynamics and knuckle images. The usability of the introduced approach was tested experimentally. The obtained results confirm that the proposed fusion method gives better results than the use of a single biometric feature only. For this reason our method can be used for increasing a protection level of computer resources against impostors. The paper presents preliminary research conducted to assess the potential of biometric methods fusion.
448933_1_En_13_Chapter.pdf (4.9 Mo) Télécharger le fichier
hal-01656256 , version 1 (05-12-2017)
Paternité
Tomasz Emanuel Wesołowski, Rafal Doroz, Krzysztof Wrobel, Hossein Safaverdi. Keystroke Dynamics and Finger Knuckle Imaging Fusion for Continuous User Verification. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.141-152, ⟨10.1007/978-3-319-59105-6_13⟩. ⟨hal-01656256⟩
76 Consultations
77 Téléchargements
