Performance and Energy in Green Superposition Coding Wireless Networks: An Analytical Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jean-Marc Kelif
  • Fonction : Auteur
  • PersonId : 993181
Azeddine Gati
  • Fonction : Auteur
  • PersonId : 917017
In this paper, we develop a powerful analytical model of wireless network with Superposition Coding (SC), also referred to as Non Orthogonal Multiple Access (NOMA). This model allows to establish a closed form expression of the minimum power a base station (BS) need to transmit, for a user to achieve a given SINR (signal to interference plus noise ratio) whatever its location in the area covered by the base station. It moreover allows to establish a closed form expression of the minimum total transmit power of a base station. These closed form expressions allow to establish performance of wireless networks, by minimizing the base stations transmit powers. As an application, we show that these closed form expressions allow to quantify the energetic performance, spectral efficiency, total throughput and the coverage of a BS, in a simple and quick way.
SuperCodGlobecom2017v14final.pdf (162.19 Ko) Télécharger le fichier
hal-01658932 , version 1 (08-12-2017)
  • HAL Id : hal-01658932 , version 1
Jean-Marc Kelif, Jean-Marie Gorce, Azeddine Gati. Performance and Energy in Green Superposition Coding Wireless Networks: An Analytical Model. GLOBECOM 2017 - IEEE Global Hub: Connecting East and West, Dec 2017, Singapour, Singapore. pp.1-6. ⟨hal-01658932⟩
117 Consultations
206 Téléchargements
