Toward an improved representation of air-sea interactions in high-resolution global ocean forecasting systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
lemarie_egu2017.pdf (7.17 Mo) Télécharger le fichier
hal-01660799 , version 1 (15-01-2018)
  • HAL Id : hal-01660799 , version 1
Florian Lemarié, Guillaume Samson, Jean-Luc Redelsperger, Hervé Giordani, Gurvan Madec. Toward an improved representation of air-sea interactions in high-resolution global ocean forecasting systems. EGU 2017 - European Geosciences Union General Assembly, Apr 2017, Vienna, Austria. pp.1-19. ⟨hal-01660799⟩
473 Consultations
341 Téléchargements
