Local criteria for triangulation of manifolds * - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Ramsay Dyer
  • Fonction : Auteur
  • PersonId : 938488
Mathijs Wintraecken
  • Fonction : Auteur
  • PersonId : 1020357
We present criteria for establishing a triangulation of a manifold. Given a manifold M , a simplicial complex A, and a map H from the underlying space of A to M , our criteria are presented in local coordinate charts for M , and ensure that H is a homeomorphism. These criteria do not require a differentiable structure, or even an explicit metric on M. No Delaunay property of A is assumed. The result provides a triangulation guarantee for algorithms that construct a simplicial complex by working in local coordinate patches. Because the criteria are easily checked algorithmically, they are expected to be of general use.
homeo.pdf (511.04 Ko) Télécharger le fichier
hal-01661230 , version 1 (11-12-2017)
Jean-Daniel Boissonnat, Ramsay Dyer, Arijit Ghosh, Mathijs Wintraecken. Local criteria for triangulation of manifolds *. 2017. ⟨hal-01661230⟩
202 Consultations
83 Téléchargements
