SURF: A new code-based signature scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
There is a serious problem with one of the assumptions made in the security proof of the SURF scheme. This problem turns out to be easy in the regime of parameters needed for the SURF scheme to work. We give afterwards the old version of the paper for the reader's convenience.
SURF.pdf (801.66 Ko) Télécharger le fichier
hal-01661786 , version 1 (29-04-2022)
Thomas Debris-Alazard, Nicolas Sendrier, Jean-Pierre Tillich. SURF: A new code-based signature scheme. 2022. ⟨hal-01661786⟩
85 Consultations
180 Téléchargements
