A Lagrangian-Based Branch-and-Bound Algorithm for the Two-Level Uncapacitated Facility Location Problem with Single-Assignment Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transportation Science Année : 2016
We consider the two-level uncapacitated facility location problem with single-assignment constraints (TUFLP-S), a problem that arises in industrial applications in freight transportation and telecommunications. We present a new Lagrangian relaxation approach for the TUFLP-S, based on solving a single-level uncapacitated facility location problem (UFLP) as the Lagrangian subproblem. We also develop a Lagrangian heuristic that includes a mixed-integer programming–based large neighborhood search heuristic exploring neighborhoods by solving a series of small UFLPs. The dual and primal bounds thus obtained are used within an enumerative algorithm that implements specialized branching rules. Our computational experiments on instances derived from an industrial application in freight transportation as well as on large, hard, artificial instances confirm the efficiency of the authors specialized branch-and-bound algorithm.
CIRRELT-2013-21.pdf (425.58 Ko) Télécharger le fichier
hal-01663639 , version 1 (14-12-2017)
Bernard Gendron, Paul-Virak Khuong, Frédéric Semet. A Lagrangian-Based Branch-and-Bound Algorithm for the Two-Level Uncapacitated Facility Location Problem with Single-Assignment Constraints. Transportation Science, 2016, 50 (4), pp.1286 - 1299. ⟨10.1287/trsc.2016.0692⟩. ⟨hal-01663639⟩
151 Consultations
782 Téléchargements
