Plane-extraction from depth-data using a Gaussian mixture regression model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Letters Année : 2018
We propose a novel algorithm for unsupervised extraction of piecewise planar models from depth-data. Among other applications, such models are a good way of enabling autonomous agents (robots, cars, drones, etc.) to effectively perceive their surroundings and to navigate in three dimensions. We propose to do this by fitting the data with a piecewise-linear Gaussian mixture regression model whose components are skewed over planes, making them flat in appearance rather than being ellipsoidal, by embedding an outlier-trimming process that is formally incorporated into the proposed expectation-maximization algorithm, and by selectively fusing contiguous, coplanar components. Part of our motivation is an attempt to estimate more accurate plane-extraction by allowing each model component to make use of all available data through probabilistic clustering. The algorithm is thoroughly evaluated against a standard benchmark and is shown to rank among the best of the existing state-of-the-art methods.
Mariott-arXiv-v2.pdf (506.91 Ko) Télécharger le fichier
hal-01663984 , version 1 (14-12-2017)
hal-01663984 , version 2 (29-03-2018)
Richard T Marriott, Alexander Pashevich, Radu Horaud. Plane-extraction from depth-data using a Gaussian mixture regression model. Pattern Recognition Letters, 2018, 110, pp.44-50. ⟨10.1016/j.patrec.2018.03.024⟩. ⟨hal-01663984v2⟩
324 Consultations
191 Téléchargements
