Maximizing microalgae productivity by shading outdoor cultures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Proceedings/Recueil Des Communications Année : 2017
Outdoor microalgae cultures can undergo a photoinhibitory process that can result in a loss in biomass productivity. This loss can be reduced by shading the culture such that the incident photon flux decreases. Based on a simple model of light-limited growth, we look for a control strategy to shadow the culture in order to maximize the biomass productivity. The strategy results in a feedback control that depends on the microalgae strain, the microalgae concentration, and the incident light. In the case that the incident light and the loss rate vary periodically in time, we give conditions for the existence of a positive periodic solution that is globally stable. We show the performance of the feedback control by means of numerical simulations.
IFAC_2017.pdf (343.58 Ko) Télécharger le fichier
hal-01666463 , version 1 (15-01-2018)
Carlos Martínez, Olivier Bernard, Francis Mairet. Maximizing microalgae productivity by shading outdoor cultures. 50 (1), Elsevier, pp.8734 - 8739, 2017, IFAC papers online, ⟨10.1016/j.ifacol.2017.08.1725⟩. ⟨hal-01666463⟩
362 Consultations
241 Téléchargements
