Event Detection in Molecular Communication Networks with Anomalous Diffusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Letters Année : 2017
A key problem in nanomachine networks is how information from sensors is to be transmitted to a fusion center. In this paper, we propose a molecular communication-based event detection network. In particular, we develop a detection framework that can cope with scenarios where the molecules propagate according to anomalous diffusion instead of the conventional Brownian motion. We propose an algorithm for optimizing the network throughput by exploiting tools from reinforcement learning. Our algorithms are evaluated with the aid of numerical simulations, which demonstrate the tradeoffs between performance and complexity.
Revised Manuscript_v3.pdf (194.39 Ko) Télécharger le fichier
hal-01671181 , version 1 (22-12-2017)
Trang C Mai, Malcolm Egan, Trung Q Duong, Marco Di Renzo. Event Detection in Molecular Communication Networks with Anomalous Diffusion. IEEE Communications Letters, 2017, 21 (6), pp.1249 - 1252. ⟨10.1109/LCOMM.2017.2669315⟩. ⟨hal-01671181⟩
221 Consultations
186 Téléchargements
