Abstract : Scientific papers potentially offer a wealth of information that allows one to put the
corresponding work in context and offer a wide range of services to researchers. GROBID is a
high performing software environment to extract such information as metadata, bibliographic
references or entities in scientific texts.
Most modern digital library techniques rely on the availability of high quality textual documents.
In practice, however, the majority of full text collections are in raw PDF or in incomplete and
inconsistent semi-structured XML. To address this fundamental issue, the development of the
Java library GROBID started in 2008 [1]. The tool exploits “Conditional Random Fields” (CRF), a
machine-learning technique for extracting and restructuring content automatically from raw and
heterogeneous sources into uniform standard TEI (Text Encoding Initiative) documents.
https://hal.inria.fr/hal-01673305
Contributor : Laurent Romary <>
Submitted on : Friday, December 29, 2017 - 10:00:22 AM Last modification on : Friday, March 27, 2020 - 3:18:30 AM
