A Model-Based Environment for Data Services: Energy-Aware Behavioral Triggering Using ADOxx - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wilfrid Utz
  • Fonction : Auteur
  • PersonId : 999551
Robert Woitsch
  • Fonction : Auteur
  • PersonId : 999550
This paper demonstrates an application case for the concept of Data Service design and composition techniques established by the Big-Data Data Service (BD-DS) modelling method realized using the ADOxx meta-modelling platform. In the domain of energy-efficiency assessments of buildings and their operations, the collection of energy related data does not pose a problem anymore as the necessary infrastructure is available in a non-intrusive way, at low installation and operation costs. An issue identified relates to the realization of value-adding services based on these continuous data streams in such distributed, heterogeneous environments. In the context of the ORBEET project, a dynamic, close-to-real-time data access/composition design and exploration framework has been realized. This framework builds upon the concept of Energy Data as a Service combining different sources for a dynamic and enhanced operational rating deployed in 4 different pilot sites in Europe.
455531_1_En_25_Chapter.pdf (1.06 Mo) Télécharger le fichier
hal-01674846 , version 1 (03-01-2018)
Paternité
Wilfrid Utz, Robert Woitsch. A Model-Based Environment for Data Services: Energy-Aware Behavioral Triggering Using ADOxx. 18th Working Conference on Virtual Enterprises (PROVE), Sep 2017, Vicenza, Italy. pp.265-275, ⟨10.1007/978-3-319-65151-4_25⟩. ⟨hal-01674846⟩
45 Consultations
67 Téléchargements
