New interface
Conference papers
A Fuzzy Load Balancer for Adaptive Fault Tolerance Management in Cloud Platforms
Abstract : To achieve high levels of reliability, availability and performance in cloud environments, a fault tolerance approach to handle failures effectively is needed. In most existing research, the primary focus has been on explicit specification-driven solutions which requires too much effort for application developers, and leads to inflexibility. We propose a fuzzy job distributor (load balancer) for fault tolerance management to reduce levels of management complexity for the user. The proposed approach aims to reduce the possibility of fault occurrences in the system by a fair distribution of user job requests among available resources. In our self-adaptive approach, the system manages anomalous situations that might lead to failure by distributing the incoming job request based on the reliability of processing nodes, i.e., virtual machines (VMs). The reliability of VMs is a variable parameter and changes during its lifetime. Our approach is implemented and comparatively analysed using OpenStack. The experimental results show a significant reduction in the occurrence of faults in comparison with other load balancing algorithms.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01677613
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, January 8, 2018 - 3:00:47 PM
Last modification on : Monday, January 8, 2018 - 3:02:59 PM
Long-term archiving on: : Thursday, May 3, 2018 - 8:05:06 PM
File
449571_1_En_9_Chapter.pdf
Identifiers
Citation
Hamid Arabnejad, Claus Pahl, Giovani Estrada, Areeg Samir, Frank Fowley. A Fuzzy Load Balancer for Adaptive Fault Tolerance Management in Cloud Platforms. 6th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2017, Oslo, Norway. pp.109-124, ⟨10.1007/978-3-319-67262-5_9⟩. ⟨hal-01677613⟩
Share
Metrics
Record views
163
Files downloads
63
