Investigating Wearable Technology for Fatigue Identification in the Workplace - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christopher Griffiths
  • Fonction : Auteur
  • PersonId : 1026177
Judy Bowen
  • Fonction : Auteur
  • PersonId : 1025906
Annika Hinze
  • Fonction : Auteur
  • PersonId : 1026178
Fatigue has been identified as a significant contributor to workplace accident rates. However, risk minimisation is a process largely based on self-reporting methodologies, which are not suitable for fatigue identification in high risk industries. Wearable technology which is capable of collecting physiological data such as step and heart rates as an individual performs workplace tasks has been proposed as a possible solution. Such devices are minimally intrusive to the individual and so can be used throughout the working day. Much is promised by the providers of such technology, but it is unclear how suitable it is for in-situ measurements in real-world work scenarios. To investigate this, we performed a series of studies designed to capture physiological and psychological data under differing (physical and mental) loading types with the intention of finding out how suitable such equipment is. Using reaction time (simple and choice) as a measure of performance we found similar correlations exist between loading duration and our measured indicators as those found in large-scale laboratory studies using state of the art equipment. Our results suggest that commercially available activity monitors are capable of collecting meaningful data in workplaces and are, therefore, worth investigating further for this purpose.
421760_1_En_22_Chapter.pdf (97.25 Ko) Télécharger le fichier
hal-01678443 , version 1 (09-01-2018)
Paternité
Christopher Griffiths, Judy Bowen, Annika Hinze. Investigating Wearable Technology for Fatigue Identification in the Workplace. 16th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2017, Bombay, India. pp.370-380, ⟨10.1007/978-3-319-67684-5_22⟩. ⟨hal-01678443⟩
64 Consultations
60 Téléchargements
