Ab Initio Simulations of Water Dynamics in Aqueous TMAO Solutions: Temperature and Concentration Effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physical Chemistry B Année : 2017
We use ab initio molecular dynamics simulation to study the effect of hydropho-bic groups on the dynamics of water molecules in aqueous solutions of trimethylamine N-oxide. We show that hydrophobic groups induce a moderate (< 2-fold) slowdown of water reorientation and hydrogen-bond dynamics in dilute solutions, but that this slowdown rapidly increases with solute concentration. In addition, the slowdown factor is found to vary very little with temperature, thus suggesting an entropic origin. All these results are in quantitative agreement with prior classical molecular dynamics simulations and with the previously suggested excluded-volume model. The hydrophilic TMAO headgroup is found to affect water dynamics more strongly than the hydropho-bic moiety, and the magnitude of this slowdown is very sensitive to the strength of the water–solute hydrogen-bond.
ms.pdf (7.49 Mo) Télécharger le fichier
hal-01682245 , version 1 (12-01-2018)
Guillaume Stirnemann, Elise Duboué-Dijon, Damien Laage. Ab Initio Simulations of Water Dynamics in Aqueous TMAO Solutions: Temperature and Concentration Effects. Journal of Physical Chemistry B, 2017, 121 (49), pp.11189-11197. ⟨10.1021/acs.jpcb.7b09989⟩. ⟨hal-01682245⟩
169 Consultations
142 Téléchargements
