Malleable task-graph scheduling with a practical speed-up model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 2018
Scientific workloads are often described by Directed Acyclic task Graphs. Indeed, DAGs represent both a theoretical model and the structure employed by dynamic runtime schedulers to handle HPC applications. A natural problem is then to compute a makespan-minimizing schedule of a given graph. In this paper, we are motivated by task graphs arising from multifrontal factorizations of sparse matrices and therefore work under the following practical model. Tasks are malleable (i.e., a single task can be allotted a time-varying number of processors) and their speedup behaves perfectly up to a first threshold, then speedup increases linearly, but not perfectly, up to a second threshold where the speedup levels off and remains constant. After proving the NP-hardness of minimizing the makespan of DAGs under this model, we study several heuristics. We propose model-optimized variants for PROPSCHEDULING, widely used in linear algebra application scheduling, and FLOWFLEX. GREEDYFILLING is proposed, a novel heuristic designed for our speedup model, and we demonstrate that PROPSCHEDULING and GREEDYFILLING are 2-approximation algorithms. In the evaluation, employing synthetic data sets and task graphs arising from multifrontal factorization, the proposed optimized variants and GREEDYFILLING significantly outperform the traditional algorithms, whereby GREEDYFILLING demonstrates a particular strength for balanced graphs.
TPDS-cameraready-noinclude.pdf (2.41 Mo) Télécharger le fichier
TPDS-supplemental-file.pdf (135.26 Ko) Télécharger le fichier
hal-01687189 , version 1 (18-01-2018)
Loris Marchal, Bertrand Simon, Oliver Sinnen, Frédéric Vivien. Malleable task-graph scheduling with a practical speed-up model. IEEE Transactions on Parallel and Distributed Systems, 2018, 29 (6), pp.1357-1370. ⟨10.1109/TPDS.2018.2793886⟩. ⟨hal-01687189⟩
174 Consultations
438 Téléchargements
