Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Book sections
Stability of LTI systems with distributed sensors and aperiodic sampling
Abstract : This chapter is dedicated to the stability analysis of sampled-data linear time invariant systems with asynchronous sensors and aperiodic sampling. The study is performed using an input/output interconnection modelling, and tools from the robust control theory. Two approaches are presented. One is based on the small gain theorem, while the other is based on the dissipativity theory. Tractable stability criteria that allow an estimation of the Maximal Admissible Sampling Period are obtained for both approaches. Finally, experimental results performed on an inverted pendulum benchmark are presented. They confirm the applicability of both approaches and allow for some comparisons between both results.
Document type :
Book sections
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01689253
Contributor : Christophe Fiter Connect in order to contact the contributor
Submitted on : Monday, July 9, 2018 - 10:05:03 AM
Last modification on : Wednesday, March 23, 2022 - 3:51:22 PM
Long-term archiving on: : Tuesday, October 2, 2018 - 7:41:02 AM
File
Fiter et al. - Springer 2018.p...
Identifiers
  • HAL Id : hal-01689253, version 1
Citation
Christophe Fiter, Taki-Eddine Korabi, Lucien Etienne, Laurentiu Hetel. Stability of LTI systems with distributed sensors and aperiodic sampling. Control subject to Computational and Communication Constraints: Current Challenges, Lecture Notes in Control and Information Sciences, Springer, 2018. ⟨hal-01689253⟩
Share
Metrics
Record views
243
Files downloads
188
