New interface
Reports (Research report)
EnosStack: A LAMP-like stack for the experimenter
Ronan-Alexandre Cherrueau 1, 2 Matthieu Simonin 3 Alexandre van Kempen 1, 2
1 LS2N - équipe STACK - Software Stack for Massively Geo-Distributed Infrastructures
Inria Rennes – Bretagne Atlantique , LS2N - Laboratoire des Sciences du Numérique de Nantes
3 MYRIADS - Design and Implementation of Autonomous Distributed Systems
Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : Reproducibility and repeatability dramatically increase the value of scientific experiments, but remain two challenging goals for the experimenters. Similar to the LAMP stack that considerably eased the web developers life, in this paper, we advocate the need of an analogous software stack to help the experimenters making reproducible research. We propose the EnosStack, an open source software stack especially designed for reproducible scientific experiments. EnosStack enables to easily describe experimental workflows meant to be re-used, while abstracting the underlying infrastructure running them. Being able to switch experiments from a local to a real testbed deployment greatly lower code development and validation time. We describe the abstractions that have driven its design, before presenting a real experiment we deployed on Grid’5000 to illustrate its usefulness. We also provide all the experiment code, data and results to the community.
Document type :
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01689726
Contributor : Alexandre Van Kempen Connect in order to contact the contributor
Submitted on : Monday, January 22, 2018 - 2:38:49 PM
Last modification on : Thursday, December 1, 2022 - 11:24:08 AM
File
RR-9146.pdf
Identifiers
  • HAL Id : hal-01689726, version 2
Citation
Ronan-Alexandre Cherrueau, Matthieu Simonin, Alexandre van Kempen. EnosStack: A LAMP-like stack for the experimenter. [Research Report] RR-9146, INRIA Rennes - Bretagne Atlantique. 2018, pp.1-14. ⟨hal-01689726⟩
Share
Metrics
Record views
497
Files downloads
286
