Challenges of mastering the energy sector and sustainable solutions for development in Africa - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2019
J. D. D. Nguimfack-Ndongmo
  • Fonction : Auteur
  • PersonId : 1027345
A. Muluh Fombu
  • Fonction : Auteur
  • PersonId : 1027346
L. L. Sonfack
  • Fonction : Auteur
  • PersonId : 1027347
R. Kuaté-Fochie
  • Fonction : Auteur
  • PersonId : 1027348
G. Kenné
  • Fonction : Auteur
  • PersonId : 1027349
The African continent is currently experiencing a period of sustained economic and population growth that requires massive investment in the energy sector to effectively meet the energy needs in the context of sustainable development. At the same time, COP21 agreements now call all the states to use clean energy. Yet a great energy potential is available, but the electrification rate of the continent currently accounts for only 3% of the world's energy production. Also, the demand for both quality and quantity energy requires the mastery of applied mathematical tools to efficiently solve problems arising in the energy system. In this article, the major problems affecting the energy sector in Africa are identified, some solutions to the challenges are recalled and some new ones are proposed, with emphasis given to applied mathematics tools as well as energy policy. As case studied, a new control strategy of Static Synchronous Series Compensator (SSSC) devices-which are modern power quality Flexible Alternating Current Transmission Systems (FACTS)-is proposed for Power Flow Control.
Le continent africain connait actuellement une période de croissance économique et dé-mographique soutenue qui requiert un investissement massif dans le secteur de l'énergie en vue d'un développement durable. Dans le même temps, les accords de la COP21 interpellent désor-mais les états à recourir aux énergies propres. Malgré son potentiel énergétique énorme, le taux d'électrification en Afrique reste très faible (3%) notamment au sud du sahara. D'autre part, la de-mande d'énergie en qualité et en quantité nécessite un recours aux outils mathématiques modernes pour résoudre les problèmes des réseaux électriques. Dans cet article, les principaux problèmes af-fectant le secteur de l'énergie en Afrique sont identifiés, certaines solutions aux défis de la maîtrise de ce secteur sont rappelées et de nouvelles solutions sont proposées, en mettant l'accent sur les outils de mathématiques appliquées ainsi que sur la politique énergétique. A titre d'illustration des nouvelles solutions mathématiques, une nouvelle stratégie de contrôle du compensateur statique, synchrone et série (SSSC) qui fait partie des systèmes modernes et flexible de transmission du courant alternatif (FACTS) est proposée pour le contrôle du flux de puissance.
ARIMA-Vol30-71-86.pdf (1.56 Mo) Télécharger le fichier
hal-01697412 , version 1 (31-01-2018)
hal-01697412 , version 2 (01-04-2019)
hal-01697412 , version 3 (03-05-2019)
J. D. D. Nguimfack-Ndongmo, A. Muluh Fombu, L. L. Sonfack, R. Kuaté-Fochie, G. Kenné, et al.. Challenges of mastering the energy sector and sustainable solutions for development in Africa. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2019, Volume 30 - 2019 - MADEV health and energy (2017), pp.16. ⟨10.46298/arima.4269⟩. ⟨hal-01697412v3⟩
240 Consultations
1616 Téléchargements
