KBE-PLM Integration Schema for Engineering Knowledge Re-use and Design Automation - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1) , (2) , (2) , (1)
1
2
Jullius Cho
  • Function : Author
  • PersonId : 1027489
Thomas Vosgien
  • Function : Author
  • PersonId : 1027490
Thorsten Prante
  • Function : Author
  • PersonId : 1027491
Detlef Gerhard
  • Function : Author
  • PersonId : 1027492
The re-use of product knowledge is vital to the development of Knowledge-Based Engineering (KBE) systems and to the deployment of Product Lifecycle Management (PLM) strategies. This paper addresses the challenges related to KBE-PLM systems integration in order to unlock engineering knowledge from proprietary representations and to manage the lifecycle of KBE models as well as their usage by different design automation applications. Essential constituents of product knowledge are identified and analyzed and the concepts of design intent and design rationale are re-introduced as key enablers to re-use this product knowledge in the appropriate KBE context. The paper introduces a KBE-PLM integration framework including a platform-independent Open KBE repository structured according to the KBE-PLM integration schema. This schema is a multi-layer neutral product and knowledge data model designed for integrating information from parameterized Computer-Aided Design (CAD) models, rule-based KBE systems and PLM systems.
434860_1_En_5_Chapter.pdf (575.36 Ko) Télécharger le fichier
Dates and versions
hal-01699692 , version 1 (02-02-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Jullius Cho, Thomas Vosgien, Thorsten Prante, Detlef Gerhard. KBE-PLM Integration Schema for Engineering Knowledge Re-use and Design Automation. 13th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2016, Columbia, SC, United States. pp.43-55, ⟨10.1007/978-3-319-54660-5_5⟩. ⟨hal-01699692⟩
144 View
164 Download
Share
