Preprints, Working Papers, ...
Data-driven stochastic inversion under functional uncertainties
Mohamed Reda El Amri 1, 2 Céline Helbert 3 Olivier Lepreux 2 Miguel Munoz Zuniga 2 Clémentine Prieur 1 Delphine Sinoquet 2
1 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
UGA [2016-2019] - Université Grenoble Alpes [2016-2019], Grenoble INP [2007-2019] - Institut polytechnique de Grenoble - Grenoble Institute of Technology [2007-2019], LJK - Laboratoire Jean Kuntzmann , Inria Grenoble - Rhône-Alpes
Abstract : In this paper, we propose a new methodology to deal with an uncertain functional input in inversion problems through computer experiments. This study is motivated by an automotive application. In this context, the simulator code takes a double set of simulation inputs : deterministic control variables and functional random variables. This framework is characterized by two features. The first feature is the high computational cost of simulations, which makes the inversion in the presence of uncertainties unaffordable. The second feature is that the probability density of the functional input V is only known through a sample of realizations. The proposed method involves two imbricated tasks. A first task based on a bayesian approach aims at wisely choosing the new evaluations of the code in order to estimate the excursion set with a limited number of costly simulations. The second task targets on efficiently estimating the expectation over the functional random variable. As the uncertain variable is observable through a finite training sample, we present three ways to infer the distribution from data. Our method is illustrated and calibrated on an analytical example. It is then applied on the automotive industrial test case where the objective is to identify the set of control parameters leading to meet the pollutant emissions standards of a vehicle.
Document type :
Complete list of metadatas
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01704189
Contributor : Mohamed Reda El Amri <>
Submitted on : Thursday, February 8, 2018 - 12:08:07 PM
Last modification on : Wednesday, October 7, 2020 - 1:12:02 PM
Long-term archiving on: : Friday, May 4, 2018 - 12:29:37 AM
File
Article_elamri.pdf
Identifiers
  • HAL Id : hal-01704189, version 1
Citation
Mohamed Reda El Amri, Céline Helbert, Olivier Lepreux, Miguel Munoz Zuniga, Clémentine Prieur, et al.. Data-driven stochastic inversion under functional uncertainties. 2018. ⟨hal-01704189⟩
Share
Metrics
Record views
1197
Files downloads
325
