Conference papers
Relationship Between Variants and Inventory Under Consideration of the Replenishment Time
Abstract : It is common wisdom that the finished goods inventory increases with the number of variants stored in that inventory. However, to the best of our knowledge, this has never been verified. This paper presents research where this relationship has been analyzed both by applying theory and through analytical simulation. The result shows that this common wisdom is not always true. The number of kanban increases as the customer takt decreases if the customer takt is smaller than the replenishment time. If the customer takt is larger than the replenishment time, a change in the customer takt will not change the required minimum inventory of one. Similar holds true for the number of variants.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01707259
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, February 12, 2018 - 4:24:57 PM
Last modification on : Thursday, May 2, 2019 - 10:22:16 AM
Long-term archiving on: : Monday, May 7, 2018 - 4:24:08 PM
File
456373_1_En_44_Chapter.pdf
Identifiers
Citation
Christoph Roser, Hauke Meier, Masaru Nakano. Relationship Between Variants and Inventory Under Consideration of the Replenishment Time. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.382-389, ⟨10.1007/978-3-319-66926-7_44⟩. ⟨hal-01707259⟩
Share
Metrics
Record views
60
Files downloads
56
