Improving Discoverability and Expert Performance in Force-Sensitive Text Selection for Touch Devices with Mode Gauges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Alix Goguey
Sylvain Malacria
Carl Gutwin
  • Fonction : Auteur
  • PersonId : 1016856
Text selection on touch devices can be a difficult task for users. Letters and words are often too small to select directly , and the enhanced interaction techniques provided by the OS – magnifiers, selection handles, and methods for selecting at the character, word, or sentence level – often lead to as many usability problems as they solve. The introduction of force-sensitive touchscreens has added another enhancement to text selection (using force for different selection modes); however, these modes are difficult to discover and many users continue to struggle with accurate selection. In this paper we report on an investigation of the design of touch-based and force-based text selection mechanisms, and describe two novel text-selection techniques that provide improved discov-erability, enhanced visual feedback, and a higher performance ceiling for experienced users. Two evaluations show that one design successfully combined support for novices and experts , was never worse than the standard iOS technique, and was preferred by participants.
improving-discoverability-expert.pdf (599.14 Ko) Télécharger le fichier
hal-01714195 , version 1 (21-02-2018)
Alix Goguey, Sylvain Malacria, Carl Gutwin. Improving Discoverability and Expert Performance in Force-Sensitive Text Selection for Touch Devices with Mode Gauges. CHI 2018 - ACM Conference on Human Factors in Computing Systems, Apr 2018, Montreal, Canada. pp.1-12, ⟨10.1145/3173574.3174051⟩. ⟨hal-01714195⟩
264 Consultations
396 Téléchargements
