Systematics aware learning: a case study in High Energy Physics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Victor Estrade
Cécile Germain
Isabelle Guyon
  • Fonction : Auteur
  • PersonId : 1025260
David Rousseau
  • Fonction : Auteur
  • PersonId : 919340
Experimental science often has to cope with systematic errors that coherently bias data. We analyze this issue on the analysis of data produced by experiments of the Large Hadron Collider at CERN as a case of supervised domain adaptation. Systematics-aware learning should create an efficient representation that is insensitive to perturbations induced by the systematic effects. We present an experimental comparison of the adversarial knowledge-free approach and a less data-intensive alternative.
systematics-aware-learning.pdf (449.08 Ko) Télécharger le fichier
hal-01715155 , version 1 (22-02-2018)
  • HAL Id : hal-01715155 , version 1
Victor Estrade, Cécile Germain, Isabelle Guyon, David Rousseau. Systematics aware learning: a case study in High Energy Physics. ESANN 2018 - 26th European Symposium on Artificial Neural Networks, Apr 2018, Bruges, Belgium. ⟨hal-01715155⟩
258 Consultations
175 Téléchargements
