Abstract : Counting the number of times a pattern occurs in a database is a fundamental data mining problem. It is a subroutine in a diverse set of tasks ranging from pattern mining to supervised learning and probabilistic model learning. While a pattern and a database can take many forms, this paper focuses on the case where both the pattern and the database are graphs (networks). Unfortunately , in general, the problem of counting graph occurrences is #P-complete. In contrast to earlier work, which focused on exact counting for simple (i.e., very short) patterns, we present a sampling approach for estimating the statistics of larger graph pattern occurrences. We perform an empirical evaluation on synthetic and real-world data that validates the proposed algorithm, illustrates its practical behavior and provides insight into the trade-off between its accuracy of estimation and computational efficiency.
