Distributed computation of vector clocks in Petri nets unfolding for test selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
It has been shown that annotating Petri net unfoldings with time stamps allows for building distributed testers for distributed systems. However, the construction of the annotated unfolding of a distributed system currently remains a centralized task. In this paper we extend a distributed unfolding technique in order to annotate the resulting unfolding with time stamps. This allows for distributed construction of distributed testers for distributed systems.
paper.pdf (346.75 Ko) Télécharger le fichier
hal-01735406 , version 1 (15-03-2018)
  • HAL Id : hal-01735406 , version 1
Loïg Jezequel, Agnes Madalinski, Stefan Schwoon. Distributed computation of vector clocks in Petri nets unfolding for test selection. Workshop on Discrete Event Systems (WODES), May 2018, Sorrento, Italy. ⟨hal-01735406⟩
174 Consultations
106 Téléchargements
