Plane-Based Multi-View Inpainting for Image-Based Rendering in Large Scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Image-Based Rendering (IBR) allows high-fidelity free-viewpoint navigation using only a set of photographs and 3D reconstruction as input. It is often necessary or convenient to remove objects from the captured scenes, allowing a form of scene editing for IBR. This requires multi-view inpainting of the input images. Previous methods suffer from several major limitations: they lack true multi-view coherence, resulting in artifacts such as blur, they do not preserve perspective during inpainting, provide inaccurate depth completion and can only handle scenes with a few tens of images. Our approach addresses these limitations by introducing a new multi-view method that performs inpainting in intermediate, locally common planes. Use of these planes results in correct perspective and multi-view coherence of inpainting results. For efficient treatment of large scenes, we present a fast planar region extraction method operating on small image clusters. We adapt the resolution of inpainting to that required in each input image of the multi-view dataset, and carefully handle image resampling between the input images and rectified planes. We show results on large indoors and outdoors environments.
philip2018mvplanarInpaint.pdf (11.79 Mo) Télécharger le fichier
hal-01745568 , version 1 (28-03-2018)
Julien Philip, George Drettakis. Plane-Based Multi-View Inpainting for Image-Based Rendering in Large Scenes. I3D 2018 - ACM SIGGRAPH Symposium on Interactive 3D Graphics and Games, May 2018, Montréal, Canada. pp.1-11, ⟨10.1145/3190834.3190846⟩. ⟨hal-01745568⟩
239 Consultations
728 Téléchargements
