A Demonstration of Evidence-Based Action Research Using Information Dashboard in Introductory Programming Education - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yoshiaki Matsuzawa
  • Fonction : Auteur
  • PersonId : 1021842
In this paper, we demonstrated an evidence-based action research in an introductory programming class with the use of an information dashboard which provides coding metrics to visualize students’ engagement of their assignments. The information dashboard was designed for teachers to improve their classroom teaching using the same coding metrics which was verified in our previous research [9]. The system was equipped with a cross-filter functionality for exploring the entire classroom metrics. Accordingly, teachers can easily conduct a temporal analysis, an across-year comparison, and a cross metrics analysis. We examined the system for the improvement of the 5th year course using a dataset from the past four years from a non-CS introductory programming course at a university. Qualitative analysis was conducted using the discourse between teachers and teaching assistants with the proposed dashboard. The results showed that the system succeeded in promoting discourse, which included a clearer understanding of the class and its improvement, such as teaching method, assignments, or of students’ behavior.
463502_1_En_62_Chapter.pdf (477.83 Ko) Télécharger le fichier
hal-01762842 , version 1 (10-04-2018)
Paternité
Yoshiaki Matsuzawa, Yoshiki Tanaka, Tomoya Kitani, Sanshiro Sakai. A Demonstration of Evidence-Based Action Research Using Information Dashboard in Introductory Programming Education. 11th IFIP World Conference on Computers in Education (WCCE), Jul 2017, Dublin, Ireland. pp.619-629, ⟨10.1007/978-3-319-74310-3_62⟩. ⟨hal-01762842⟩
71 Consultations
151 Téléchargements
