A Survey of the Prior Programming Experience of Undergraduate Computing and Engineering Students in Ireland - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Glenn Strong
  • Fonction : Auteur
  • PersonId : 1030489
Catherine Higgins
  • Fonction : Auteur
  • PersonId : 1030490
Nina Bresnihan
  • Fonction : Auteur
  • PersonId : 1030491
Richard Millwood
  • Fonction : Auteur
  • PersonId : 1030492
It has become apparent that increasing numbers of students arriving into undergraduate computing and engineering degree programmes in Irish 3rd-level institutions have prior experience of computer programming. As the extent of this prior exposure as well as its nature, origins, and usefulness is not known beyond anecdotal evidence, an annual survey of prior programming experience of freshman undergraduates who study programming as part of their degree has been designed and administered. This paper reports on the first two years of this survey in 2015 and 2016. It found that around one third had some prior experience of programming with nearly half of that group reporting a reasonable level of fluency in one or more languages. The authors expect that the effect of proposed changes to primary and 2nd-level curricula alongside the increasing popularity of informal programming clubs will be increasingly felt in coming years and therefore plan to continue and extend the survey in order to clarify the effect of such developments. The results should be of interest to 3rd-level educators in the planning of curriculum and teaching practice.
463502_1_En_48_Chapter.pdf (202.24 Ko) Télécharger le fichier
hal-01762850 , version 1 (10-04-2018)
Paternité
Glenn Strong, Catherine Higgins, Nina Bresnihan, Richard Millwood. A Survey of the Prior Programming Experience of Undergraduate Computing and Engineering Students in Ireland. 11th IFIP World Conference on Computers in Education (WCCE), Jul 2017, Dublin, Ireland. pp.473-483, ⟨10.1007/978-3-319-74310-3_48⟩. ⟨hal-01762850⟩
49 Consultations
227 Téléchargements
