Flexible Best Fit Assembly of Large Aircraft Components. Airbus A350 XWB Case Study - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (1)
1
Rebeca Arista
  • Function : Author
  • PersonId : 1030640
Hugo Falgarone
The need for assembly parts and structures where the perfect fitting is not guaranteed due to manufacturing/assembly tolerances and/or the influence of several physical effects, i.e. gravity, is increasing constantly in different industrial sectors and in particular in the aerospace industry.Some techniques have been developed to deal with it. In the field of large aero structures, custom-made parts using reverse engineering techniques are used to machine parts whose geometry requires to be customized for each produced aircraft. In the field of aircraft shells, a technique based on the characteristics of non-rigid components that can be slightly deformed to clear geometrical conditions by controlled forces to strain within its stress limits.FITFLEX project exploit this last technique and was carried out by Airbus Group Innovations and Airbus. The objective is supporting the Airbus A350 XWB ramp-up and the current manual positioning process of the shell by force control, defining a measurement based assembly including a flexible best-fit system.The case subject of study on FITFLEX project is the A350 XWB rear fuselage, a 14 m by 5 m side shell positioning process.
462132_1_En_14_Chapter.pdf (456.95 Ko) Télécharger le fichier
Dates and versions
hal-01764150 , version 1 (11-04-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Rebeca Arista, Hugo Falgarone. Flexible Best Fit Assembly of Large Aircraft Components. Airbus A350 XWB Case Study. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.152-161, ⟨10.1007/978-3-319-72905-3_14⟩. ⟨hal-01764150⟩
207 View
312 Download
Share
