Development of a Smart Assembly Data Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current technological advances pave the way for highly flexible production processes within Cyber-Physical Production Systems (CPPS). In a CPPS, every component being produced may be represented by a virtual data model containing its own unique information. Components are also information carriers with communication features enabled by an Internet-based exchange of information. The exchange of information between components and with the production system may happen over the whole manufacturing process. The availability of detailed information about every component supports the implementation of optimized assembly processes, called Smart Assembly of smart components. Smart Assembly is an approach to assembling different components according to unique specifications of every product variant, and considering the most efficient combination of components for each assembly. Therefore, a structured component data model considering data storage and data access is needed. However, for the Smart Assembly of smart components, the underlying data structure and processes have to be developed. The objective of this paper is to propose a data structure to enable the Smart Assembly of components in an assemble-to-order production scenario. To achieve the proposed objective, two use cases have been developed to simulate the Smart Assembly of smart components.
462132_1_En_58_Chapter.pdf (380.48 Ko) Télécharger le fichier
hal-01764193 , version 1 (11-04-2018)
Paternité
Luiz Durão, Sebastian Haag, Reiner Anderl, Klaus Schützer, Eduardo Zancul. Development of a Smart Assembly Data Model. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.655-666, ⟨10.1007/978-3-319-72905-3_58⟩. ⟨hal-01764193⟩
121 Consultations
155 Téléchargements
