Docker Container Deployment in Fog Computing Infrastructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The transition from virtual machine-based infrastructures to container-based ones brings the promise of swift and efficient software deployment in large-scale computing infrastructures. However, in fog computing environments which are often made of very small computers such as Raspberry PIs, deploying even a very simple Docker container may take multiple minutes. We demonstrate that Docker makes inefficient usage of the available hardware resources, essentially using different hardware subsystems (network bandwidth, CPU, disk I/O) sequentially rather than simultaneously. We therefore propose three optimizations which, once combined, reduce container deployment times by a factor up to 4. These optimizations also speed up deployment time by about 30% in datacenter-grade servers.
main.pdf (396.04 Ko) Télécharger le fichier
hal-01775105 , version 1 (24-04-2018)
Arif Ahmed, Guillaume Pierre. Docker Container Deployment in Fog Computing Infrastructures. IEEE EDGE 2018 - IEEE International Conference on Edge Computing, Jul 2018, San Francisco, CA, United States. pp.1-8, ⟨10.1109/EDGE.2018.00008⟩. ⟨hal-01775105⟩
1223 Consultations
2753 Téléchargements
