The geometry of the flex locus of a hypersurface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pacific Journal of Mathematics Année : 2020
La géometrie du lieu flex d'une hypersurface
We give a formula in terms of multidimensional resultants for an equation for the flex locus of a projective hypersurface, generalizing a classical result of Salmon for surfaces in P3. Using this formula, we compute the dimension of this flex locus, and an upper bound for the degree of its defining equations. We also show that, when the hypersurface is generic, this bound is reached, and that the generic flex line is unique and has the expected order of contact with the hypersurface.
SalmonFlexes.pdf (479.01 Ko) Télécharger le fichier
hal-01779785 , version 1 (26-04-2018)
Laurent Busé, Carlos d'Andrea, Martín Sombra, Martin Weimann. The geometry of the flex locus of a hypersurface. Pacific Journal of Mathematics, 2020, 304 (2), pp.419--437. ⟨10.2140/pjm.2020.304.419⟩. ⟨hal-01779785⟩
451 Consultations
194 Téléchargements
