Full-Reference Image Quality Assessment Measure Based on Color Distortion - Archive ouverte HAL Access content directly
Conference Papers Year : 2015
(1) , (2)
1
2
The purpose of this paper is to introduce a new method for image quality assessment (IQA). The method adopted here is assumed to be Full-reference measure. Color images that are corrupted with different kinds of distortions are assessed by applying a color distorted algorithm on each color component separately. This approach use especially YIQ color space in computation. Gradient operator was successfully introduced to compute gradient image from the luminance channel of images. In this paper, we propose an alternative technique to evaluate image quality. The main difference between the new proposed method and the gradient magnitude similarity deviation (GMSD) method is the usage of color component for the detection of distortion.Experimental comparisons demonstrate the effectiveness of the proposed method.
339159_1_En_6_Chapter.pdf (1003.21 Ko) Télécharger le fichier
Dates and versions
hal-01789962 , version 1 (11-05-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Zianou Ahmed Seghir, Fella Hachouf. Full-Reference Image Quality Assessment Measure Based on Color Distortion. 5th International Conference on Computer Science and Its Applications (CIIA), May 2015, Saida, Algeria. pp.66-77, ⟨10.1007/978-3-319-19578-0_6⟩. ⟨hal-01789962⟩
256 View
352 Download
Share
