Mixed batches and symmetric discriminators for GAN training - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Generative adversarial networks (GANs) are powerful generative models based on providing feedback to a generative network via a discriminator network. However, the discriminator usually assesses individual samples. This prevents the dis-criminator from accessing global distributional statistics of generated samples, and often leads to mode dropping: the generator models only part of the target distribution. We propose to feed the discriminator with mixed batches of true and fake samples, and train it to predict the ratio of true samples in the batch. The latter score does not depend on the order of samples in a batch. Rather than learning this invariance, we introduce a generic permutation-invariant discriminator architecture. This architecture is provably a universal approximator of all symmetric functions. Experimentally, our approach reduces mode collapse in GANs on two synthetic datasets, and obtains good results on the CIFAR10 and CelebA datasets, both qualitatively and quantitatively.
mixed_batches_sym_disc_for_gans_with_ack (1).pdf (4.18 Mo) Télécharger le fichier
hal-01791126 , version 1 (19-06-2018)
hal-01791126 , version 2 (05-07-2018)
  • HAL Id : hal-01791126 , version 2
Thomas Lucas, Corentin Tallec, Jakob Verbeek, Yann Ollivier. Mixed batches and symmetric discriminators for GAN training. ICML - 35th International Conference on Machine Learning, Jul 2018, Stockholm, Sweden. pp.2844-2853. ⟨hal-01791126v2⟩
809 Consultations
484 Téléchargements
