MongoDB I/O Access Patterns are under the Microscope
This poster introduces how eBPF is used as an experimental method to discover I/O issue of a clustered MongoDB.
We show how such a tracing method addresses the limitation of high-level evaluation where the focus is limited on high-level metrics.
