Terahertz adaptive optics with a deformable mirror - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optics Letters Année : 2018
We report on the wavefront correction of a terahertz (THz) beam using adaptive optics, which requires both a wavefront sensor that is able to sense the optical aberrations, as well as a wavefront corrector. The wavefront sensor relies on a direct 2D electro-optic imaging system composed of a ZnTe crystal and a CMOS camera. By measuring the phase variation of the THz electric field in the crystal, we were able to minimize the geometrical aberrations of the beam, thanks to the action of a deformable mirror. This phase control will open the route to THz adaptive optics in order to optimize the THz beam quality for both practical and fundamental applications.
DM(version HAL).pdf (1.59 Mo) Télécharger le fichier
hal-03525133 , version 1 (13-01-2022)
Mathilde Brossard, Jean-François Sauvage, Mathias Perrin, Emmanuel Abraham. Terahertz adaptive optics with a deformable mirror. Optics Letters, 2018, 43 (7), pp.1594-1597. ⟨10.1364/OL.43.001594⟩. ⟨hal-03525133⟩
165 Consultations
165 Téléchargements
