On minimal decompositions of low rank symmetric tensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Linear Algebra and its Applications Année : 2020
We use an algebraic approach to construct minimal decompositions of symmetric tensors with low rank. This is done by using Apolarity Theory and by studying minimal sets of reduced points apolar to a given symmetric tensor, namely, whose ideal is contained in the apolar ideal associated to the tensor. In particular, we focus on the structure of the Hilbert function of these ideals of points. We give a procedure which produces a minimal set of points apolar to any symmetric tensor of rank at most 5. This procedure is also implemented in the algebra software Macaulay2.
LowRankPolynomials.pdf (487.69 Ko) Télécharger le fichier
hal-01803571 , version 1 (30-05-2018)
Bernard Mourrain, Alessandro Oneto. On minimal decompositions of low rank symmetric tensors. Linear Algebra and its Applications, 2020, 607, pp.347-377. ⟨10.1016/j.laa.2020.06.029⟩. ⟨hal-01803571⟩
192 Consultations
236 Téléchargements
