Light field video dataset captured by a R8 Raytrix camera (with disparity maps)
In response to the call for Visual Test Material for immersive applications [N17462, N17471] video content acquired with a R8 Raytrix camera and converted into 5x5 Multiview format is proposed. Each view is provided with a disparity map.
