Monolithic Fluid Structure Interaction Model, Application to Water Entry Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We consider the interaction between an air-water flow and a rigid structure using a fast accurate numerical model. Following the 3D low Mach compressible Euler model previously developed and validated, a compressible fluid-structure interaction model is proposed. In the context of a fictitious domain, a volumic penalization is applied inside the body to ensur a rigidity constraint through a penalized velocity in order to get the correct motion of the rigid body. The accuracy of this simple model is improved using block-based adaptive mesh refinement technique. The improvement and the validity of our fluid-structure interaction procedure is investigated through the numerical simulation of the water entry of a cylinder freely falling and impacting the water. This test case is compared to experimental data and other numerical simulations.
proc_2018_TPFD_Prague.pdf (484.47 Ko) Télécharger le fichier
hal-01805263 , version 1 (10-12-2021)
Frederic Golay. Monolithic Fluid Structure Interaction Model, Application to Water Entry Problem. Topical Problems of Fluid Mechanics 2018, Feb 2018, Prague, Czech Republic. ⟨10.14311/TPFM.2018.016⟩. ⟨hal-01805263⟩
Collections
UNIV-TLN IMATH
70 Consultations
27 Téléchargements
