Data-Efficient Design Exploration through Surrogate-Assisted Illumination
Design optimization techniques are often used at the beginning of the design process to explore the space of possible designs. In these domains illumination algorithms , such as MAP-Elites, are promising alternatives to classic optimization algorithms because they produce diverse, high-quality solutions in a single run, instead of only a single near-optimal solution. Unfortunately, these algorithms currently require a large number of function evaluations, limiting their applicability. In this article we introduce a new illumination algorithm, Surrogate-Assisted Illumination (SAIL), that leverages surrogate modeling techniques to create a map of the design space according to user-defined features while minimizing the number of fitness evaluations. On a 2-dimensional airfoil optimization problem SAIL produces hundreds of diverse but high-performing designs with several orders of magnitude fewer evaluations than MAP-Elites or CMA-ES. We demonstrate that SAIL is also capable of producing maps of high-performing designs in realistic 3-dimensional aerodynamic tasks with an accurate flow simulation. Data-efficient design exploration with SAIL can help designers understand what is possible, beyond what is optimal, by considering more than pure objective-based optimization.
Domains
Computer Science [cs] Robotics [cs.RO] Computer Science [cs] Artificial Intelligence [cs.AI] Computer Science [cs] Computational Engineering, Finance, and Science [cs.CE] Computer Science [cs] Computer Aided Engineering Engineering Sciences [physics] Mechanics [physics.med-ph] Fluids mechanics [physics.class-ph] Statistics [stat] Machine Learning [stat.ML]
