Symmetry Aware Evaluation of 3D Object Detection and Pose Estimation in Scenes of Many Parts in Bulk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While 3D object detection and pose estimation has been studied for a long time, its evaluation is not yet completely satisfactory. Indeed, existing datasets typically consist in numerous acquisitions of only a few scenes because of the tediousness of pose annotation, and existing evaluation protocols cannot handle properly objects with symmetries. This work aims at addressing those two points. We first present automatic techniques to produce fully annotated RGBD data of many object instances in arbitrary poses, with which we produce a dataset of thousands of independent scenes of bulk parts composed of both real and synthetic images. We then propose a consistent evaluation methodology suitable for any rigid object, regardless of its symmetries. We illustrate it with two reference object detection and pose estimation methods on different objects, and show that incorporating symmetry considerations into pose estimation methods themselves can lead to significant performance gains. The proposed dataset is available at http://rbregier.github.io/dataset2017.
bregier_iccvw2017.pdf (6.8 Mo) Télécharger le fichier
bregier_poster.pdf (1.28 Mo) Télécharger le fichier
bregier_supplementary_material.pdf (818.76 Ko) Télécharger le fichier
hal-01819659 , version 1 (20-06-2018)
Romain Brégier, Frédéric Devernay, Laetitia Leyrit, James L. Crowley. Symmetry Aware Evaluation of 3D Object Detection and Pose Estimation in Scenes of Many Parts in Bulk. 2017 IEEE International Conference on Computer Vision Workshop (ICCVW), Oct 2017, Venice, France. pp.2209-2218, ⟨10.1109/ICCVW.2017.258⟩. ⟨hal-01819659⟩
193 Consultations
384 Téléchargements
