Abstract : Recommender systems evaluation is usually based on predictive accuracy metrics with better scores meaning recommendations of higher quality. However, the comparison of results is becoming increasingly difficult, since there are different recommendation frameworks and different settings in the design and implementation of the experiments. Furthermore, there might be minor differences on algorithm implementation among the different frameworks. In this paper, we compare well known recommendation algorithms, using the same dataset, metrics and overall settings, the results of which point to result differences across frameworks with the exact same settings. Hence, we propose the use of standards that should be followed as guidelines to ensure the replication of experiments and the reproducibility of the results.
https://hal.inria.fr/hal-01821035 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, June 22, 2018 - 11:44:17 AM Last modification on : Friday, June 22, 2018 - 12:00:56 PM Long-term archiving on: : Tuesday, September 25, 2018 - 7:46:30 PM
Nikolaos Polatidis, Stelios Kapetanakis, Elias Pimenidis, Konstantinos Kosmidis. Reproducibility of Experiments in Recommender Systems Evaluation. 14th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2018, Rhodes, Greece. pp.401-409, ⟨10.1007/978-3-319-92007-8_34⟩. ⟨hal-01821035⟩
