SmartInspect: Solidity Smart Contract Inspector - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Solidity is a language used for smart contracts on the Ethereum blockchain. Smart contracts are embedded procedures stored with the data they act upon. Debugging smart contracts is a really difficult task since once deployed, the code cannot be re-executed and inspecting a simple attribute is not easily possible because data is encoded. In this paper, we address the lack of inspectability of a deployed contract by analyzing contract state using decompilation techniques driven by the contract structure definition. Our solution, SmartInspect, also uses a mirror-based architecture to represent locally object responsible for the interpretation of the contract state. SmartInspect allows contract developers to better visualize and understand the contract stored state without needing to redeploy, nor develop any ad-hoc code.
Braga18a-IWBOSE-SmartInspect.pdf (851.04 Ko) Télécharger le fichier
hal-01831075 , version 1 (05-07-2018)
Santiago Bragagnolo, Henrique S C Rocha, Marcus Denker, Stéphane Ducasse. SmartInspect: Solidity Smart Contract Inspector. IWBOSE 2018 - 1st International Workshop on Blockchain Oriented Software Engineering, Mar 2018, Campobasso, Italy. ⟨10.1109/IWBOSE.2018.8327566⟩. ⟨hal-01831075⟩
523 Consultations
1909 Téléchargements
