Abstract : Smart meters networks are rapidly becoming a
reality in many developed countries. In this paper, we focus on
the optimization of a network of smart meters operated by the
wM-Bus protocol, which is the de-facto metering standard in
Europe. In such a scenario, data concentrators receive data from
smart meters using the wM-Bus protocol and relay it to a central
server using a legacy mobile cellular backhauling technology such
as GSM/GPRS. Due to the massive amount of data produced by
meters installed in urban scenarios and the association-less nature
of the wM-Bus protocol, data concentrators may be overloaded
with many duplicate measurement packets, causing capacity
problems on the backhauling links and computational overload
at the central server. To solve these issues, we propose a datadriven
optimization framework to populate forwarding whitelists
at each data concentrator so that (i) load is balanced among the
different concentrators and (ii) the overall performance of the
network in terms of packet reception rate and received signal
strength are maximized. We also propose a heuristic algorithm
to generate near optimal forwarding whitelists in acceptable
computing time. Extensive experiments are performed on a real
scenario consisting of a city wide gas meter network deployed in
northern Italy. Results show that the proposed heuristic is able
to produce whitelists that reduce the average backhauling traffic
as much as 80%, with a corresponding network quality within
4% of the one computed by the optimal solution.
https://hal.inria.fr/hal-01832493 Contributor : Joe TurnerConnect in order to contact the contributor Submitted on : Saturday, July 7, 2018 - 6:31:50 PM Last modification on : Tuesday, August 13, 2019 - 11:10:04 AM Long-term archiving on: : Tuesday, October 2, 2018 - 2:52:34 AM
Andrea Pimpinella, Alessandro E. C. Redondi, Matteo Cesana. Load Balancing and Performance Optimization in wM-Bus Smart Meter Networks. 17th Annual Mediterranean Ad Hoc Networking Workshop (Med-Hoc-Net 2018), Jun 2018, Capri Island, Italy. pp.7-14. ⟨hal-01832493⟩
