Fast transforms over finite fields of characteristic two - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2021
Transformées rapides sur les corps finis de caractéristique deux
We describe new fast algorithms for evaluation and interpolation on the "novel" polynomial basis over finite fields of characteristic two introduced by Lin, Chung and Han (FOCS 2014). Fast algorithms are also described for converting between their basis and the monomial basis, as well as for converting to and from the Newton basis associated with the evaluation points of the evaluation and interpolation algorithms. Combining algorithms yields a new truncated additive fast Fourier transform (FFT) and inverse truncated additive FFT which improve upon some previous algorithms when the field possesses an appropriate tower of subfields.
transforms.pdf (375.93 Ko) Télécharger le fichier
hal-01845238 , version 1 (20-07-2018)
hal-01845238 , version 2 (05-09-2019)
hal-01845238 , version 3 (22-01-2021)
Nicholas Coxon. Fast transforms over finite fields of characteristic two. Journal of Symbolic Computation, 2021, 104, pp.824-854. ⟨10.1016/j.jsc.2020.10.002⟩. ⟨hal-01845238v3⟩
212 Consultations
645 Téléchargements
