C2-SENSE – Pilot Scenario for Interoperability Testing in Command & Control Systems for Crises and Disaster Management: Apulia Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marco Di Ciano
  • Fonction : Auteur
  • PersonId : 1035251
Agostino Palmitessa
  • Fonction : Auteur
  • PersonId : 1035252
Domenico Morgese
  • Fonction : Auteur
  • PersonId : 1035253
Denis Havlik
  • Fonction : Auteur
  • PersonId : 983201
Gerald Schimak
  • Fonction : Auteur
  • PersonId : 983200
Different organizations with their Command & Control (C2) and Sensing Systems have to cooperate and constantly exchange and share data and information in order to manage emergencies, crises and disasters. Although individual standards and specifications are usually adopted in C2 and Sensing Systems separately, there is no common, unified interoperability specification to be adopted in an emergency situation, which creates a crucial interoperability challenge for all the involved organizations. To address this challenge, we introduce a novel and practical profiling approach, which aims at achieving seamless interoperability of C2 and Sensing Systems in emergency management. At the end of this interoperability challenge a Pilot Application is set up and will be tested in the field to demonstrate the advantages resulting from this effort. This paper gives an overview about the involved entities in the pilot application scenario and the testing of the system functionality by using predefined micro-scenarios suitable for the pilot region in Apulia.
467210_1_En_22_Chapter.pdf (893.95 Ko) Télécharger le fichier
hal-01852642 , version 1 (02-08-2018)
Paternité
Marco Di Ciano, Agostino Palmitessa, Domenico Morgese, Denis Havlik, Gerald Schimak. C2-SENSE – Pilot Scenario for Interoperability Testing in Command & Control Systems for Crises and Disaster Management: Apulia Example. 12th International Symposium on Environmental Software Systems (ISESS), May 2017, Zadar, Croatia. pp.263-278, ⟨10.1007/978-3-319-89935-0_22⟩. ⟨hal-01852642⟩
89 Consultations
104 Téléchargements
